Results 1 to 8 of 8
  1. #1
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    Sunroof Drain Help Needed
    Well, it appears my drains in the sunroof are blocked. I had mud dripping out of my OnStar mike today after washing. I really don't want to go research in thet other place and was hoping people would share the trick to cleaning these out. I seem to remember something about a bicycle brake cable.
    Help? Pics would be good. I think I found the drains in the front part but can not find the back ones.
    Thanks in advance.
    2006 Hummer H3 / Adventure / 5 Speed / No Bling
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  2. #2
    Mud Terrain
    Join Date
    Sep 2011
    Maryland
    Posts
    854
    Thanks
    98
    you can use an air compressor with a hose to blow the buildup out. You just have to be careful not to blow the drain hoses off of where they attach
    My Garage
  3. The Following User Says Thank You to benlaud87 For This Useful Post:
    cbetts (01-08-2012)
  4. #3
    Mud Terrain
    Join Date
    Sep 2011
    Sunset, Utah
    Posts
    914
    Thanks
    124
    There's a drain in each corner of the sun roof tub. I'm not sure where the back ones run down to. The front run down the A pillar to high up on the front firewall and stop there. You can follow them down by removing the inside molding on the A-pillar. Then the end of the dash panel just pulls off. The tube runs down to a connector in the firewall. It has a thin rubber membrane with a cross cut into it. I had to cut othe passenger side one on mine. Haven't had a preoblem since.
    Good luck
    Know your Bugs Bunny.... Very important.
  5. The Following User Says Thank You to deserth3 For This Useful Post:
    cbetts (01-08-2012)
  6. #4
    Join Date
    Sep 2011
    Posts
    6,310
    Thanks
    2,074
    Here's a link to TXH3T's thread. Hope this helps:
    http://www.hummer4x4offroad.com/foru...ad-a-roof-leak
    “Life's hard. It's even harder when you're stupid.”
    John Wayne
  7. The Following User Says Thank You to Bigunit For This Useful Post:
    cbetts (01-08-2012)
  8. #5
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    I was reminded that I have a shop manual so I pulled it out and read . . .
    I started off with wire but it was unable to budge the clot. I quick burst of compressed air did the trick. Here is what blew out.
    Here are pics of the drains for future reference:
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  9. The Following User Says Thank You to cbetts For This Useful Post:
    cgalpha08 (01-16-2012)
  10. #6
    Street Tire
    Join Date
    Sep 2011
    Illinois
    Posts
    380
    Thanks
    22
    Nice pics! I always wondered where the drains were
  11. The Following User Says Thank You to H3nightrod For This Useful Post:
    cbetts (01-16-2012)
  12. #7
    Low Profile
    Join Date
    Dec 2011
    Blue Ridge Mountains,VA
    Posts
    92
    Thanks
    5
    I have this problem to. Was going to blow some air in it.
    Once the line is clear, will pouring a glass of water in there and looking for a puddle bellow the truck confirm that the line is clear and I did not blow any lines off? Thinking of just using a low psi air pump. Is there a specific place where the puddle forms when all is functioning well?
  13. #8
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    Quote Originally Posted by FOXedupONE View Post
    Yep! You should see a puddle just like the picture above (hopefully a little cleaner than mine!). The water should come out just behind the inner fender.
    As the shop manual indicates, use a max of 35PSI on the air pressure.
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
