Page 1 of 5 12345 LastLast
Results 1 to 15 of 64
  1. #1
    Bald Tire
    Join Date
    Jan 2012
    Sacramento, CA
    Posts
    15
    Thanks
    1
    Post Throttle body and MAF sensor cleaning
    Throttle body and MAF sensor cleaning on 3.7l I-5 H3
    It was time to change my air filter so i decided to check the Throttle body and give it a scrub down too.
    I think this took me about an hour to complete. Itís not difficult at all, just take care with the MAF sensor as it is a sensitive piece of equipment.
    To start, the tools i used:
    10mm nut driver
    Phillips screw driver
    The cleaning sprays I used:
    1. Disconnect battery.
    2. Disconnect plug at MAF sensor.
    3. Loosen 2 clips on the air box lid and the hose clamp on the air outlet hose between air box and resonator. I removed the hose at the resonator so that I could remove the air box lid and hose assembly that houses the MAF sensor all together.
    4. With the air intake out of the way you now have access to the vortec resonator. Loosen and remove the 2 bolts (10mm) that hold the resonator to the valve cover and loosen the hose clamp where the short air outlet duct attaches to the TB. With the resonator loose you can swing it out of the way in order to access the 4 bolts (10mm) that hold the TB.
    5. Disconnect the sensor plug and the vacuum hose on the throttle body.
    6. Loosen the 4 TB bolts and remove, holding the TB as it will fall away once the last bolt is taken out.
    7. With the TB removed I took it to the work bench and cleaned it down with the TB cleaner, an old toothbrush, and a lint free rag. what a difference.
    8. With the TB clean I allowed it to dry and attacked the MAF sensor (gently).
    9. The MAF sensor is mounted in the air box lid, where the air inlet hose connects, with 2 Philips screws.
    Removing it is easy, just be sure not to touch any of the inner workings as this is a delicate and expensive instrument. To be safe I didnít touch anything that resides inside the air intake. Sorry about the out of focus pics here. I didnít realize until everything was reassembled.
    10. Spray down the sensor using the MAF sensor cleaner only and allow it to dry thoroughly.
    11. Leaving the MAF sensor to dry, reinstall the TB in the reverse order of the tear-down. Check your gasket where the TB bolts on. Make sure it doesn't need to be replaced and the it is free of debris before installing the TB.
    12. At some point go back to the MAF sensor and secure it back into it's housing.
    13. Might as well replace the air filter and then install the air box lid/inlet hose.
    14. Reconnect battery
    15. Done.
    2009 H3 Adventure.
  2. The Following 23 Users Say Thank You to Boerwarrior For This Useful Post:
    ??? (12-16-2016), 06 H3 (09-20-2013), 3Hummers (12-21-2014), amrg (08-02-2013), cbetts (08-17-2012), chascoll (12-03-2012), Clwnshu99 (09-30-2015), Cyouincourt007 (06-12-2017), Dennis (02-13-2014), ENASNI (11-28-2015), Enter Hummer (06-12-2017), falcon (10-02-2015), Firesquirt (04-23-2013), Gunner_45 (02-14-2014), H3slate (02-23-2012), Haykal Bafana (07-07-2014), JoshuaL (08-17-2012), Nacho (02-23-2012), Pappibri (02-23-2012), Ron46 (04-18-2013), Schwarttzy (01-09-2014), SickStringC (06-03-2013), WillieMo (04-18-2013)
  3. #2
    Brush raked
    Join Date
    Sep 2011
    Tualatin, Oregon
    Posts
    976
    Thanks
    316
    Nice writeup. I just did this while I was customizing my intake air box.
    http://www.hummer4x4offroad.com/foru...Air-Intake-Mod
    2009 Hummer H3 Championship Edition, 6 speed auto , 35" Discoverer STT Pro, powdercoated oem wheels, Black Widow dual exhaust, Bilstein 5160's front, 5100's rear, Safari Snorkel, Projector Headlights, LED Fog Lights, remote start, blacked out trim, oem rock sliders, Knight Metal Works Expedition roof rack with 4 6x9 KC's, 2 mounted ammo boxes, hi-lift mount, and tie downs, Knight Metal Works Undercarriage protection, Tomp low profile rear leaf spring plates
  4. #3
    Bogger
    Join Date
    Jan 2012
    Cohoctah, MI
    Posts
    1,613
    Thanks
    742
    Good writeup. Just did mine about a week ago.. Helped out with idle and better response..
    2008 H3, Leveled, 315/75/16 Goodyear Duratrac's, CBUCP, Air Doc, Aries Brushguard, Rola Roof Rack, Rocky Road Rock Rails, K&N Filter, Homemade Winch Mount, Badlands 12,000 Winch, Taillight Guards, Purple Cranium Diff Cover
    Love Life, Live Life, and Love Your Hummer !!!!!!
  5. #4
    Guardian Angel
    Join Date
    Sep 2011
    Raleigh, NC
    Posts
    2,282
    Thanks
    379
    Great writeup. Thanks.
    "Ex Umbris Venimus"
    Sent from my iPhone
    Facebook NC Hummer Group
    https://www.facebook.com/groups/NCHummers/
    ReconH3 Build Thread v2.0
    http://www.hummer4x4offroad.com/foru...ld-Thread-v2.0
    ReconH3 Garage
    http://www.hummer4x4offroad.com/foru...age_view&id=35
    Quote Originally Posted by goob3r View Post
    Your truck is HUMMER porn, seriously.
  6. #5
    Join Date
    Sep 2011
    Posts
    8,556
    Thanks
    478
    Nice writeup, best I've seen so far on this.
  7. #6
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    8,816
    Thanks
    1,021
    great write up
    Squeaky3: 06 H3 ALPHA SAS Hi pinion Dana 44 front/Eaton HO72 rear 5.13 gears, custom crossmember for long arms, lockers, 4:1 T-case, v8 swap, gobi, Smittbilt 12k Custom bumpers....do it all vehicle
    "H3 front axles are like drunk cheerleaders....just use em until they get mouthy...then toss em and get another." -anonymous
  8. #7
    Chapter President
    Join Date
    Sep 2011
    Central Florida
    Posts
    1,144
    Thanks
    180
    Reminds me I need to do a little TLC on the H2.
    B I G 2 D A B A N K
    2005 H2 SUT, Desert Sand
  9. #8
    Needs a sponsor
    Join Date
    Sep 2011
    Wilmington NC
    Posts
    41
    Thanks
    18
    Re: Throttle body and MAF sensor cleaning
    Thanks for the write up, ended up doing this today and now my truck is purring like a kitten.
    Sent from my DROID RAZR using Tapatalk 2
    -Griff
    2007 Hummer H3 I5 Adv/lux, 33'' BFG KM2's, CBPhoto front winch shelf, Smittybilt COMP Series 10000 ilb winch, Custom Fuel Rack.
  10. #9
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    My truck just started to throw a P0171 code. Time to follow your procedure!
    2006 Hummer H3 / Adventure / 5 Speed / No Bling
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  11. #10
    NEVERENDING ADDICTION
    Join Date
    Sep 2011
    Mineral Bluff GA
    Posts
    254
    Thanks
    58
    Looks like I'm going to be doing a little TLC on my H3 now.
    06 Hummer H3
    Rancho 4'' lift
    18'' KMC Hoss wheels
    325/65r18s Fierce Attitude MT's
    ThorParts front bumper
    Daystar Upper Dash Panel
    Custom Brush Guard
  12. #11
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    My throttle body was a tad bit dirty:
    I think I found the source of the grime. Looks like a lot of oil has been reaching the vapor recovery tube.
    I guess the steep hills have caused the engine to inhale a little oil. Maybe I am suffering from the same issue as Alex with the burning oil on extreme climbs. You can see more evidence in the AirDoc:
    I spent some time with some cleaner and got it all prettied up. I even sprayed some cleaner on a rag to wipe out the inside of the intake manifold a bit.
    After reassembly, I shot some MAF cleaner into the MAF and let it dry. Not to noticeable on the test drive afterwards. The computer was acting weird and kept the engine running at 2500 RPM until I came to a stop. After driving around for about fifteen minutes, the problem went away.
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  13. #12
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    I am having issues with the truck keeping the RPMs up. As I approach stop signs, I pop it into neutral and coast the last few feet. The truck insists at keeping the RPMs around 2000 until I am at a full stop. My ScanGauge is showing the TPS reacting the same as the RPMs. The only thing I did was clean the throttle body and MAF. Nothing else.
    Opinions?
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  14. #13
    Needs a sponsor
    Join Date
    Sep 2011
    Wilmington NC
    Posts
    41
    Thanks
    18
    Crazy I thought I was alone for a long while. I just cleaned the throttle body... Definitely alot better, I was thinking maybe the tranny was going. Something like a clutch for a manual, because when I relieve the engine of stress it seems to calm down and steady. The AC also can have the same effect if running. Idk what it is but it's common for the H3 to rough idle.... Got me, a buddy was thinking it's along the line of a electronic problem... Idk where to start
    -Griff
  15. #14
    NERD!!!
    Join Date
    Sep 2011
    Lomita, CA
    Posts
    3,040
    Thanks
    2,101
    One thing to add to the list . . . disconnect the battery for a night to reset the computer. Once I did this, normality was restored. I also noticed improvement in power comparing to how it ran before the TB cleaning.
    2013 Kia Soul+
    2017 Honda HR-V
    My mod list:
    My build thread:
  16. #15
    Mud Terrain
    Join Date
    Feb 2012
    Wisconsin
    Posts
    891
    Thanks
    7
    Great write up... Does this really alter / change things that much?
    Chris
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
