Results 1 to 10 of 10
  1. #1
    Street Tire
    Join Date
    Jan 2013
    north carolina
    Posts
    361
    Thanks
    27
    Question plastic window trim replacement?
    so as you can see in the pics my trim is cracked and doesnt fit right around the mirror. i have tried to search that part with no luck, can anyone point me in the right direction? or maybe have a set!
    also what might have caused that to break (obviously some trying to take them off) but why would you need to?
  2. #2
    All Terrain
    Join Date
    Apr 2013
    Florissant, Co.
    Posts
    592
    Thanks
    692
    When I got my H3, it was from the dealer and I had them replace my broken one. The dealer ordered it and they had to buy the whole wrap to fix that same problem. If that helps?
    Just slowly buildin and wheelin
  3. #3
    All Terrain
    Join Date
    Mar 2013
    florida
    Posts
    542
    Thanks
    28
    I'm not home right now but I think I have the part number there. If I recall though they are $90. There's 2 plastic clips inside and I bet they are broken off in the pillar causing it to not sit flush.
  4. #4
    Street Tire
    Join Date
    Jan 2013
    north carolina
    Posts
    361
    Thanks
    27
    yeah i just noticed they were broken and i dont think the dealer will do anything its been about 4 months lol ik right how could i have not noticed.....
  5. #5
    Baja
    Join Date
    Jun 2012
    Ridgecrest, California
    Posts
    1,276
    Thanks
    119
    Those were a recall item, I had mine replaced that way.
    Mike
    2006 H3 Adventure
  6. #6
    Street Tire
    Join Date
    Jan 2013
    north carolina
    Posts
    361
    Thanks
    27
    well if its a recall item how do i go about that or is there a time limit on that kinda thing?
  7. #7
    Baja
    Join Date
    Jun 2012
    Posts
    1,276
    Thanks
    119
    I would guess go to hummer service they can run the vin and find out what recall items were performed already. Since its a recall I don't believe not being the original owner matters. Maybe Zach has some input....
    Mike
    2006 H3 Adventure
  8. #8
    Join Date
    Sep 2011
    Posts
    8,556
    Thanks
    478
    I don't believe it was a recall - I think the only recall was the hood louver. There may be a TSB on A pillars but that wouldn't guarantee a replacement piece for you.
    It appears you likely have two issues: broken A pillar trim and broken pieces on the roof into which the A pillar trim interlocks.
    The A pillar trim must come off with any windshield replacement. They are prone to breaking as well even without being pulled off for a windshield repair. There are male tabs on the underside which clip into female pieces set in the A pillar. You can always try to get some help from the dealer but if not, then you have to make a choice - replace these, which will probably break again, or do a workaround.
    Either way, the roof trim probably won't be a big deal if you get the A pillar trim nicely secured. The different workarounds out there can really secure that trim down so that the interlocking piece into the roof trim isn't as much of a necessity. People have secured them with doublestick tape, silicone and screws.
  9. #9
    Baja
    Join Date
    Jun 2012
    Posts
    1,276
    Thanks
    119
    My memory sucks. All I remember is that the issue was brought to my attention from GM, I never even noticed they were cracked :-)
    Mike
    2006 H3 Adventure
  10. #10
    Street Tire
    Join Date
    Jan 2013
    north carolina
    Posts
    361
    Thanks
    27
    Well I'm gonna tall gm! See what they can tell me, hopefully at the least I can order some....
Similar Threads
  1. Plastic shift fork
    By Reloader in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 05-03-2015, 11:33 PM
  2. Removing Chrome from Plastic (How To)
    By Steve #1 in forum Tech Library
    Last Post: 01-07-2013, 04:12 PM
  3. H3 How hot can I bake my plastic
    By machineguneddie in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 10-16-2012, 12:16 PM
  4. H3 Does anyone have the "Headlining Trim Panel Replacement" instructions?
    By NGA H3 in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 04-24-2012, 09:22 PM
  5. plastic parts part numbers??
    By cgalpha08 in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 11-03-2011, 12:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
