Okay good info to know. Yeah my front diff cross member is bouncing over dirt/gravel roads due to it being worn out. I'm going to remove it and send it in for that upgraded unit with the new poly bushing as soon as I can.
My H3 Alpha came with either raised torsion bars or new keys, extended shackles in the rear (still has OEM shocks which I think are almost out of upward travel), an ARB front bumper, Warn M8000 Winch, 4 new 33 BFG AT KO's and completely new brake pads/rotors all the way around. Only issue I've had since owning it was the CEL came on after I brought it home on it's 5.5hr journey, and I pulled the code and simply found the throttle body dirty. I cleaned it, reset the throttle body position (read how on a 5.3L chevy forum), and the CEL hasn't returned. Since it had 111K on it when I bought it I went ahead and changed the plugs and wires. I used some Autolite plugs, and some 60.00 spark plug wires from Advanced Auto Parts. My MPG went from 13MPG on the highway to nearly 16MPG so it certainly helped.
I have removed the steps, and I recently just bought a Colorado Cluster, but they sent me an older unit with the DRL icon vs the Stability Control Icon so my message center is clueless about the traction control being enabled/disabled, but I am working on getting the proper model from 355 Nation. I'd love a cluster with everything but TPMS lol.
