Chase Wright
- Denton, Texas, United States
Does anyone know if there is a way to have an actual working hood vent?
So fab a hole right under the factory hood louver thing and stick one of these fans in there to pull air out. Then have some guy fab a custom air vent to go over it? Or just just slits in the oem cover?
http://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=30100400
That's how I would do it I think... but... why fix what isn't broke..
Gotcha. So easiest/cheapest way to go is take off plastic bit, cut vent holes in plastic bit, cut the two holes in the hood itself, mount two 140mm ish waterproof fans, and mount an on off switch of course.It is broke. That's why it needs fixing. H3s are known for overheating, especially Alphas. No need for a custom vent. There's already many aluminum aftermarket ones that are functional. The cheaper option is to open up OEM one. I was going to do that until I found an aftermarket one already made. I don't think a large 16" fan would be optimal because the holes cut into the hood are two separate ones that are smaller. I would use two smaller fans like they use in computers. I haven't added the fans yet, but I do have a temp activated switch to turn them on when it hits 190. Even without the fans I can already see the heat coming out when stopped at a traffic light.
"Ex Umbris Venimus"
I don't think I'd do for functionality. Moving more air through the hood is only going to have a marginal effect. The only way to improve cooling significantly is a more efficient radiator. The cosmetic hood panel is only there to imitate the military HMMWV's functional hood louvers for its steeply slanted radiator. If it was effective on the H3, GM would have put louvers in the hood die and saved the $ for the fake louver panel. I know they test for adequate airflow through the radiator/engine bay.
I know I have cracks in my exhaust manifold, that probably doesn't help with under-hood temps although I don't know how much that affects the engine/radiator temps. I wonder how many others with temp problems have exhaust manifolds putting hot air into the engine bay?
I only say it because back in the 90s when I was visiting my old digs at U of Mich, I saw the front end of a GMC truck, engine and all, undergoing flow analysis in the ship model test tank.I'm not sure I'd believe that with GM... louvers are a custom item for very good reason (C7 excepted), there are as many downsides as there are benefits. the trick is still to get the air out, in is easy...
