- Tardville
I'm hooked on the Airbag/Daystar combo. Even though I haven't tried it out yet...I can tell its going to work great. It fills a void between a passive bump stop, and an add-a-leaf. I'm familiar with air bumps but never used them. I'm pretty sure an air bump is not made to drive around on and support the weight of the truck...its only made to absorb a hit. And I think that's the big difference. This Airbag/Daystar combo is sort of like an air bump...but it also allows you to adjust for cargo, trailers, and the notorious saggy butt that all H3's eventually get. The airbags are totally capable of supporting the truck. They have a big 6" diameter footprint and they are made to carry the weight. Best of all...with the Daystar cradles, the airbag essentially disconnects and doesn't limit the droop. Nor do you have to worry about over stretching and possibly ripping a bag (hah-hah...he said "bag").
As for the "clapping"? I suppose that's possible on a high-speed whoop or something but, I was thinking more about 5 mph and under crawling. The bag doesn't come off the cradle unless you are close to max-droop. And God forbid you are going fast when you hit max-droop in this thing. "Clapping" sounds will be the least of your worries! You'll be spitting-out teeth and possibly your tongue, (and that's if you somehow kept it upright).
