So a few weeks ago i had my check engin light come on. I took it to autozone to have the code ran and was told it was a input speed sensor gone bad. I bought the part for $60 from the dealer and a couple days ago I had my wife take the truck to a transmission shop to have it installed since i'm out of town, in order to install it the tranny has to be dropped as this sensor goes inside, cost $750. I get a call yesterday from the shop and when the dropped it the transmission fluid was a "strawberry milkshake" color and said my radiator had cracked and the transmission fluid and antifreeze had mixed together. it had been sitting in there for at least 3 weeks that i know of but unsure how long before the light came on it had leaked. so i remeber hearing something from TAPD about his H3T and a similar experince so i called him up, same issue. the only really to do is get a transmission overhaul to save itt or otherwise it will be a ticking time bomb, TAPD said his only lasted six months after the incident and his water hadnt been in there as long as mine, so i took his advice to have the tranny overhauled now instead of paying for a service and then down the road have to do the whole thing again. My truck only has 95k miles on it and TAPD said his had 36k miles. The only real solution to keep this from happening is to get an external transmission cooler seperate from the "shared" radiator and tranny cooler. Once this radiator cracks you have no way of knowing its bad until its too late, all said and done this is gonna cost around $2100 for new radiator and transmission cooler and the overhaul. I will be flushing my engine and installing the coolers myself to save an extra $300. So with this terrible lesson learned, and my truck has been taken good care of and maintained well, i highley suggest everyone get that external transmission cooler installed asap to save yourself from a major head ache. from what ive seen they run around $40ish. The factory setup is garbage and no failsafe.
