08 Alpha Slow Cranking
lfootmatt
AZ
ALPHA OWNERS:
Tried 2 different fully charged batteries. Always starts, just labors to spin it. Weak starter? Cables are good, as are the terminals that are set screwed and soldered with no corrosion present in the connection or cable. Connections at the starter are clean and tight.
Let me know your thoughts, thanks!!!
Matt L.
Providing your cables are good, battery good, and connections are clean, and wires at the starter are tight and not pinched or frayed at their connectors ....I'd say remove & take the starter apart. Have a look inside. Usually the problems are obvious. They're easy and fun to rebuild. A couple possibilities come to mind:
1) Pitted solenoid contacts: If the starter is original, or really old, the solenoid on the starter has large electrical contacts inside, which when the solenoid plunger gets "pulled back" prior to the motor engaging, when the solenoid plunger bottoms out, the contacts on the plunger bridges the gap between electrical contacts and allows current to flow between the big battery + cable and the starter motor. If you were to cut open an old solenoid, those heavy copper contacts become real pitted and eroded away after many yrs. That pitting or low contact area can cause reduced current flow and a slow starter. Make it spin slower.
2) Worn Brushes: Brushes are the electrical contact from the starter body to the spinning motor shaft. They ride on the shaft Commutator. They are high in carbon and wear due to sparking, etc which is normal. Brushes are a certain length and eventually they wear out just as pencil lead eventually wears out. They can be replaced pretty inexpensively. If your starter has age to it, this or #1 (or both) are likely your problems. Worn brushes eventually won't have enough material to contact the commutator and eventually won't work at all.
3) Flooded with oil. And engine oil leak seems to always get onto and inside engine starters. They can get oil-logged (like water-logged). And that can cause a slow starter. If your truck is dry and clean underneath, this won't be your issue.
4) Corroded or damaged cable/bar: On the starter motor itself there is usually a metal bar or often a short braided cable ...or a couple inches which connects current from the solenoid to the actual starter motor. These cables can corrode over time. Especially in the salty or rainy northern states. Idk about AZ.
5) Heat-damaged field coils: This is a problem on starters, esp starters located close to the exhaust.
6) Poor Ground/s: Ensure the engine and body grounds are good. It doesn't hurt to run a jumper cable from the battery neg to the starter body (not electrical contacts).
7) Other: There are a few other things which can go wrong in a starter, like worn bushings, failed part, things like that. A 'Bendix' (one-way starter drive) can fail, but that makes a high-pitched 'Ziiiiiiing!!' noise, not your current problem.
There you go. You can buy a new or rebuilt starter, but I encourage you to remove and disassemble your vehicle's starter. Understanding a starter or Alternator is good knowledge in case you ever need to do an unexpected field repair. There are places on the internet including ebay/Amazon and specialized places which sell all sorts of starter parts, and of course all sorts of how-to videos. You might save a few bucks... but overall, it's fun to do and good to know. Let us know what it turns out to be... :)
lfootmatt
AZ
Thanks for the info! I have the Rainman of starters and alternators local to me. Pretty much a mad scientist shop! He will call out what you carry in before you get to the mad cluttered counter. “Old prestolite marine alt, no parts any more for that one….” Whopner is on at 5….
I’ll pull it next time I’m under it; cats, front driveshaft, etc, etc…. Gotta gave it done by Christmas before the boy gets back from AIT.
Later,
Matt
That's good. I'm sure he can re-do it in a snap. Or ...rebuilt starters have gotten a lot cheaper (and better) than they used to be.
On my Jeep, it cranked slow for quite a while (years). Then it became intermittent. The brushes were worn to a nub. But hey they lasted since '87! Cranks like new now :)
Happy Hummer
Wisconsin
Actually, it is pretty easy-ish. Did sitting on my garage floor a few years back. Not a total rebuild or anything but ripped it all apart and cleaned the entire inside and replaced basic stuff. Starter was oiled soaked and quite old, grungy. Tested after it was done and still a lil slow, so replaced with brand new one. This of course was on my 2001 Jeep Cherokee XJ which is a breeze to get starter out of. H3 not so much.
lfootmatt
AZ
Ugh! Sad, my Rain man of alternators and starters shop is permanently closed, and the phone number is disconnected. I hope the old guy just retired!
Teahead
Tacoma
Hmm...mine was like that until I changed the battery.
Get yourself some Stinger battery terminals.
Spray some battery terminal cleaner on the starter terminals. May want to check the resistance of the cable to the starter.
lfootmatt
AZ
Battery terminals new a while back, set screws and soldered in place. Zero corrosion in the cables.
New A/C Delco Gold starter with all connections well cleaned.
And good battery. Never cranked so strongly. Thanks all!
Merry Christmas!!!!
Matt
lfootmatt
AZ
Yep, we’ve had it since fall of 2017. It never cranked that strongly!
Problem solved, just a crappy old starter with only 120K ish miles.
