Does anyone know the size of the O-Ring that goes between the reservoir and pump? My H3 developed a leak on Christmas Day, and I thought I had found the issue, but after a flush of the system along with several days of driving the leak is back. This time I'm 99% sure the leak is between the reservoir and pump. I tried finding the part online, but in the end I found a better deal on the OEM complete pump, reservoir, and cap vs just buying another reservoir.
Besides the leak between the reservoir and pump nothing is wrong with my old unit. I've got to tear into it either way to fix it so that's why I'm just going to replace the entire assembly while I'm at it. I would like to repair the old unit and make it a good working trail spare. If no one knows about the O-Ring size I'll take it apart, match it, and report back.
My P/S needed attention anyways as it was dark with a slight burnt smell. I flushed it good and used some Royal Purple fluid/conditioner so after the leak is fixed I should be good to go.
I've got another question while I'm at it. I've seen those Rack & Pinion aluminum braces for our H3's. Do you have to completely remove the rack to install just the new aluminum bracket? I looked at my bushings and they're in great shape.
