-12 offset rims
ChrisClass
New Jersey
Hello everyone,
I'm in the market for a new set of rims.Anyone running 18 x 9 inch rims with a -12 offset,and if so any rubbing.
-thanks
Offset means nothing without width. The offset dimension is taken from the center of the width....so a -12mm offset on a 7", 8", 9" and 10" widths, will all have different backspace dimensions. Backspace is the real dimension, and it is fool proof. It tells you exactly how much space you have and it is referenced from the inner edge of the rim, which is constant regardless of the rim width.
The offset will help you compare how much a tires centerline moves In/Out when comparing wheels of different width.
A +10mm, 8" wheel will be 22mm inside your fenders than a -12mm, 9" wheel. As 4speedfunk mentioned, backspacing will tell you how much clearance you have between the wheel and suspension/brake items. Offset and backspacing can be calculate from each other.
Stock offset is +38, a -12 offset means the tire centerline will move outwards 50mm (2"). If your running 35s, you won't be able to run that wheel without a lift.
My friend is running +2mm with 35s, barely clears the rear of the front fenders, and he has a Body lift!
Yeah...Good example amrg. Wheel calculation is a real mess these days. Not only is there the "offset" and "backspace" math...but also the inches & metric conversion. Sometimes hard to stay on top of it. At first you might think a -12mm offset is crazy, and you might wonder why it would be set so far outboard?....then you realize the stock wheels are +38mm (7.5" rim with 5.5" b.s.). Suddenly that number doesn't seem so bad!
I always go back to what I knew from the 70s & 80s, when every truck ran 0-offset wheels. Basically an 8" wide wheel had 4" backspacing. It made the math simple. But nowdays most stock vehicles have the wheels steeply offset to the inboard, and we don't have near the wheel-well area that we used to back then (except for the H3). Long story short...H3 guys typically run a 9" wide wheel, and the -12mm seems to work well for most of us (including Rancho lifted trucks). This offset & width actually comes very close to the old 70s & 80s truck wheels in terms of fit and appearance. I would never run POSITIVE offset wheels but, then again I don't have sub-woofers and tv-screens all over it either. To each his own, I guess.
One final thing: Make sure you get wheels with at least a 4" centerbore (approx. 100mm). The H3 has larger hubs than many other vehicles (including all the other GM 6-lug trucks), so they need a larger hole in the middle to clear them. That trips up a lot of H3 owners, and more than once I've stories of guys ordering wheels only to find out later, that the centerbores are too small.
If you wheel your truck, 315s (35s) are the way to go.
If not, and you want driveablity, you can make do with 305s (34s) on an I5. An Alpha has no problem pushing 315s (the alpha comes stock with 285s (33s) )
However with the -12 offset, 315s won't clear the front fenders (could be solved with a 1" Body lift but I'm only sure of -6 offset and different tire brands have different tire diamters)
