2006 h3 hummer bad clunk when taking off help!
CBH
OHIO
Have 2006 h3 hummer. Have sever clunk when taking off... Replaced wheel bearings..stabilizer arm left side. Left axel.. Differential bushings. Still clunking. Took front drive shaft out and vehicle will not move. Thinking transfer case. Any thoughts on here
taylorblake831
western washington
it sounds like your rear carrier in your diff is broke… maybe drain the fluid and look for a lot of metal shavings (there is always going to be small amounts from a diff)
cbetts
NERD!!!
Rancho Palos Verdes, CA
If you took out the front shaft, you will need to put the transfer case in 4 Hi Lock. Remember that the H3 is all wheel drive. If clunk is gone, I would suspect the front diff mount(s).
