HummerHead
- California
Hello Fellow Hummer Owners,
Just happened to me today 03/19/2023. I felt something on my Hummer H3 while I was driving on a freeway, that every time that reving up a bit I can hear sounds like a grinding noise and you a little bit of a jerk when catching up to speed up. I came back home to check and smells like a burnt fluid or oil. I check my transmission fluid levels since to be fine and look under i found a bit of wet pans but no major leaks. I start the engine again while at park position then reving up looks a grinding noise is worst. My Hummer has 465,000 plus Miles in it. Has anyone had a same problem even lower mileage than I am?Is anyone? still driving a Hummer with the same mileage as me?
