2008 h3 alpha fan clutch
Jeasen
Bonner Springs, KS 66012
Previous owner had the water pump replaced but old fan clutch is still in place. I want to replace the fan clutch but GM has discontinued part #25844696. What are you guys using in its place? I tried doing a search but nothing came up?
None of the parts listings shows an alternate. Rock Auto shows a water pump with a fan clutch attached but I already have a new water pump.
Acer4LO
Illinois
The Hayden one is actually a heavy duty one which will give you better performance over OEM. That being said, if for some reason you want the OEM one, I actually do have one used. Has less than 1000 miles on it. I bought it back a while ago, but then I upgraded to the Hayden one.
