H3 2008 H3 Front End Leak
Calamitygirl
Born to Wheel
Wyandotte, Michigan
I noticed grease dripping near left front end of Solar. Not sure when it started. A few new drops in the last 2 days.
Taking her to dealer tomorrow just wanted to get some ideas what it might be. Front axle or CV joint maybe?
Thanks guys
What's the fluid smell like? If its nasty and distinctive it probably is diff fluid and that may come from a bad axle seal.
CV joint wouldn't be fluid but grease. My guess is diff fluid from a bad seal.
Other possibilities are PS fluid but that would normally drip on the right front side.
ArtHummer
Gaithersburg/MD
turn the wheel all the way on the side and look behind it. if you see allot of grease around than it is a CV joints. This is the only "very think" substance... I would bet on the broken CV boot.
autumn walker
Nova Scotia, Canada
Sounds like a torn CV boot to me as well. Not sure if you can replace the boot on the H3, but it is a MUCH cheaper alternative on the H2 than replacing the entire axle.
I had to replace the axle on my H3 and will have to do it soon on the H2 because of failed CV boots - the H3 was done under warranty (great dealership) and the H2 will be out of pocket, but I plan to go aftermarket.
IMO...half-shafts are consumable parts. Think of them as brake pads. Keep a fresh pair on the shelf and get in the habit of swapping them every 60K miles or so. Even sooner if you rip a CV-boot. This applies to ANY IFS rig. Its just part of playing the game. Always replace them in pairs...the failure rates on CV-joints are so predictable that it doesn't make sense to replace just one side, unless its very early in its lifespan. Soon as you get one side done...the other will blow within a month or two. Hopefully your dealer will do both sides and replace the axle seals too. This is a common leak spot, and for the extra $10...they might as well replace them while they have the shafts pulled.
Technically the dealer has no obligation to replace both sides but, back when GM was worth a crap...this was standard practice. These days there is no consistency and even less credibility among GM service centers...so you sort of "get what they give you". I've heard stories of H3's going in for a simple seal replacement...and coming out with a new steering rack, tie-rods, and two new half-shafts & seals. But that's probably not gonna happen. Fortunately on the H3...all of this stuff is very easy to change, and anybody that off-roads one should get familiar with the job. All you need is basic hand tools, a large socket for the hub, and of course...a big hammer.
One last thing to note: Don't screw around with disassembling a shaft to replace a CV-joint. There are vehicles where this is cost effective but, on the H3...the quality of the part is simply not worth the hassle. Instead, just do a core-exchange on the entire shaft and get some fresh NAPA or Cardone shafts, for about $100 per side. Put em in...blow em up...repeat as necessary. Remember...treat em like brake pads.
chaos254
That's good to know 4speedfunk. Would you recommend replacing the half shafts if doing both axle seals? I have 48k and both front axle seals have minor seepage.
Sent from my ADR6425LVW using Tapatalk 2
I got 120,000 on my CVs before I replaced them as a cautionary measure. Boots were replaced twice under warranty. Axle seals were also each replaced once under warranty. I replaced them again when doing the CV swap.
In my opinion, 48k or even 60k is very conservative.
I agree with Alrock, and to make a note....
GM's policy since 1990 was to replace only the part that was broken so long as it did not affect safety or driveability. So, in the case of a shaft, they would replace only the side that failed; however, the greater majority of shafts that fail under normal driving for normal wear is way over warranty periods. Those that fail early are usually the result of a torn boot or other damage. In fact for shocks, if it is under 12K on the factory shocks, they would replace only the failed side. Over 12K, they would approve both sides.
I also do not believe replacing both is necessary if the boot is torn from off-roading. If very high mileage and the boot is worn from flexing...I would agree. But if obviously torn, do a very close inspection of the other boot for cracks and flexibility and if ok, save your money.
Calamitygirl
Born to Wheel
Wyandotte, Michigan
Classic HUMMER replaced the left front CV axle and output shaft seal. They were very accomodating as always, gave me a brand new Silverado to drive and Solar was washed and ready when I got there after work.
The invoice said L/F diff output shaft leaking due to seal groove in C/V axle. They said just normal wear/tear. And they know I use my truck for what it was intended!
All covered under powertrain warranty!
Thank you to everyone for you input.
