slidster2010
- Denton Tx
I have a 2008 Hummer H3 3.7l base model. 2 problems going on, with the reduced power mode. When I stop, goes into reduced power mode. Driving at highway speeds, if I hit a slight bump it goes into reduced power mode. Pulled codes on check engine light, an these are the codes I get.
P0651: 5-V Reference 2 circuit
P0335: Crank Position Sensor Circuit
P2135: TPS 1-2 Correlation
C0240: Powertrain Control Module(PCM) Traction Control not allowed
All 4 wheel drive modes work, I can turn traction control off. It still goes into reduced power mode. Although I haven't tested it in 4Low. Any help would be greatly appreciated.
