mavrikjc
- Dallas, TX
So out of nowhere (truck has had no issues other than a mucked Transmission Pan leak thanks to the good folks at Jiffy Lube) my power steering decides to sporadically go MIA/stop working (nearly completely) at low RPMs.
Example: You are about to miss your exit on the highway so you brake hard and start to get over the right lane to make your exit (braking, low RPMs) and the steering wheel becomes VERY stiff and difficult to turn.
Example: You are slowly creeping into a tight parking spot at your local Wally World and suddenly your steering becomes very stiff (low RPMs).
I'm getting the unusual pump whine noise whenever this happens.
I did the trick where you sit on gravel, put the vehicle in neutral, turn the steering wheel left then right (to full lock) and have difficulty And pump whine. Then, while still in NEUTRAL (in the event anyone reads this and try's it), slowly increase RPMs by giving it some gas and then turn the wheel - no issues/difficulty/stiffness and no pump whine when RPMs get over 1000-1500.
I've heard some folks say replace the whole pump, and others say it could be aeration in the pump lines. I haven't done anything to the rack/steering/changed fluid/anything. Also, the problem is sporadic. Sometimes it happens, sometimes it's just fine (low RPMs, pulling into parking spots, etc.).
I've got a trip to Barnwell Mountain on the 24-27 in Gilmer, TX and don't want to deal with this on the trail so thinking of just replacing the pump unless someone else has dealt with this and has any ideas...
Also, checked for leaks/hoses/etc. and nothing visible (or at least nothing easily detectable, drips on ground, etc.).
I read in a general auto mechanics forum that my serpentine belt tensioner may just need tightened up a bit and could be "slipping" at low RPM but curious if any one else had the issue.
I'm about to lift the front-end up and do the bleeding procedure but curious how air could have entered a "closed' system... Then take a look at my belt tensioner...
Worth at shot though till I hear any other ideas?
Thanks in advance!
Thanks in advance!
