295/75R/16 Help
Raleigh, NC
Hey guys, I see mostly posts about 285//75R/16 and 305's and 315's... Question is plain and simple. Will a 295/75R/16 fit on a standard 16 inch Hummer rim and not rub anywhere?
I know the tire thing has been beaten to death, but like I said I habe not seen any postings for the 295/75R/16. :emb:
Thanks Guys.
SolidusJ
FT. Carson, CO
That's Frumaker tire size, but he's running aftermarket wheels with spacers. He seems to not have much trouble when we are out.
3rdH3
Blacksburg, VA
A friend of mine did it on an 06 and had no problems. I looked really good but the only drawback to that size is a very limited selection.
I had that size at one time with no issue. As has been mentioned, it's an oddball size and can be tough to locate. For example, if you cut a tire it can be a day or two to get a replacement in.
It may rub on the swaybar (mine did) but many of the larger tires do. It's not a safety issue unless of course you like to do high-speed donuts at full lock.
Raleigh, NC
Thanks for the info... Maybe I should just stick with the 285/75R/16 when I upgrade. Those will work with no problems or rubbinhg, at least that is what I understand from other posts.
