They did a concept of it, but is it possible to put the LS7 7.0L V8 into either the Alpha or base model? I don't plan on doing this but I was wondering would it actually work?
The LS2, LS3, and LS7 blocks are the same dimensions externally. Difference is going to be parts installed to the blocks such as heads, intake, oil pans, FEAD, etc.
LS7 is almost an inch taller than an LS2 IIRC due to intake manifold and heads.
