AC button blinking and no AC
lfootmatt
AZ
Greetings,
2008 H3 Alpha, 125,000 ish miles.
AC light blinks 3 times then goes out and no AC.
I’ve checked the likely culprits. Pressures look good as best I can tell with a crappy top off bottle.
I’m leaning toward the temp sensor in the evaporator core.
Does anyone have any experience or advice for this one?
Thanks!
Matt
Happy Hummer
Wisconsin
Typically indicates a system fault, with common causes including low refrigerant, a bad compressor, electrical issues like a faulty control module or wiring, etc. The blinking light tells the computer to disengage the compressor.
HummerMan7
Bronx, NY
From what I know three blinks usually mean the HVAC sees a fault and won’t let the compressor turn on, start with real manifold gauges (not a top-off can), check the A/C fuse/relay, and see if the clutch is getting a command. If charge and power are good, look at the pressure transducer and evap temp sensor next, and pull HVAC codes with a scan tool to confirm before buying parts.
lfootmatt
AZ
Thanks for the info!
One more thing, the entire AC system was replaced 3 years ago.
Ran incredibly cold in spite of being in Arizona in a hot running Alpha.
I’ll have my son get it scanned. I don’t think my cheesy cheap scan tool will see the AC system.
Thx!
