- Scottsdale
Amazon's become a great source for OEM and aftermarket parts for the H3, as well as tools. I thought I'd start a compilation of links to make it a bit easier for everyone that wants to use Amazon as a resource.
Drivetrain
ACDelco 290-297 GM Original Equipment Front Axle Shaft Seal
https://amzn.to/3mE8yx8
ACDelco 291-315 GM Original Equipment Rear Axle Shaft Seal
Genuine GM 26064028 Differential Drive Pinion Gear Seal
Rear Locker Rebuild: https://www.hummer4x4offroad.com/forum/showthread.php/14845-Rear-E-Locker-Service-Kits-what-gives
Eaton #29296-00S Gear Service Kit
https://www.summitracing.com/search/part-type/differential-carrier-rebuild-kits-and-spider-gears?fr=part-type&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=eaton #29296-00S
Eaton #29305-00S Locking Mechanism Kit
https://www.summitracing.com/search...rdMatch&SortOrder=Ascending&keyword=29305-00S
Eaton #29393-00S Stator/Armature Kit
https://www.summitracing.com/search...rdMatch&SortOrder=Ascending&keyword=29393-00S
Brakes & Suspension
ACDelco 17D1119CH Professional Durastop Ceramic Front Disc Brake Pad Set
https://amzn.to/3xJaOtu
ACDelco 18A1776 Professional Durastop Front Disc Brake Rotor
https://amzn.to/3xKYuco
ACDelco 17D1120CH Professional Durastop Ceramic Rear Disc Brake Pad Set
https://amzn.to/3xIKAXZ
ACDelco 18A1777 Professional Durastop Rear Drum In-Hat Disc Brake Rotor
https://amzn.to/3twHvYt
ACDelco 45D2432 Professional Front Lower Suspension Ball Joint Assembly
https://amzn.to/3aKWffS
Bilstein (24-186643) 5100 Series Shock Absorber
https://amzn.to/3QhajhG
Engine & Transmission
ACDelco PF61E Professional Engine Oil Filter
https://amzn.to/3aUaC1G
ACDelco GM Original Equipment 10-9395 Dexron VI Automatic Transmission Fluid - 1 gal
https://amzn.to/3xJoepn
ACDelco 24225323 Professional Automatic Transmission Fluid Filter Kit
https://amzn.to/3QcsPaZ
ACDelco 15-40508 GM Original Equipment Engine Cooling Fan Clutch
ACDelco 22304M Professional Upper Molded Coolant Hose
https://amzn.to/3QaPSTv
ACDelco 24523L Professional Lower Molded Coolant Hose
https://amzn.to/3MIvAOi
ACDelco RC85 GM Original Equipment 15 P.S.I. Radiator Cap
https://amzn.to/3xHTUva
ACDelco 213-1649 GM Original Equipment Engine Camshaft Position Sensor
https://amzn.to/3MLoqc3
ACDelco 213-3519 GM Original Equipment Engine Camshaft Position Sensor
https://amzn.to/3QjNCcm
Miscellaneous
Dorman 604-188 HVAC Blend Door Actuator Compatible with Select Hummer / Pontiac / Saturn Models
https://amzn.to/3Qat8CW
ACDelco GT306 GM Original Equipment Fuel Tank Cap
http://smile.amazon.com/gp/product/B0010GK3SM
ACDelco 25892279 GM Original Equipment Transfer Case Vent
http://smile.amazon.com/gp/product/B005OUQ9LU
(OEM style) Dorman 609-130 TPMS Grey Plastic Sealing Valve Cap, Pack of 50
http://smile.amazon.com/gp/product/B002P8EMGI
25 Cowl & Fender Push-Type Clips Hummer Torrent
http://smile.amazon.com/gp/product/B0040CW0CK
Allstar Performance ALL50855 Bleeder Screw Cap, (Set of 10)
http://smile.amazon.com/gp/product/B009Q76TVW
Tools & Other
Performance Tool W86556 Clip Removal Plier
http://smile.amazon.com/gp/product/B003WZRLZ2
Irwin Industrial Tools 2078300 8-Inch Self-Adjusting Wire Stripper with ProTouch Grips
http://smile.amazon.com/gp/product/B000OQ21CA
Lisle 56750 Seal Puller
http://smile.amazon.com/gp/product/B0002SRCKG
ACDelco 774224 10-4019 Silicone Brake Lubricant - 8 oz
http://smile.amazon.com/gp/product/B0026JK8FU
25 Hex Head Sems Body Bolts M8-1.25 X 42mm Phosphate (extra long bolts that work for skid plates)
http://smile.amazon.com/gp/product/B0040CYVV8
Ingersoll Rand SK4C3F 1/2-Inch Drive 3-Piece Lugnut Service Flip Impact Socket Set
http://smile.amazon.com/gp/product/B000HGKR5K
Original Quick Fist® Clamp for mounting tools & equipment 1" - 2-1/4" diameter (Pack of 2)
http://smile.amazon.com/gp/product/B000CQPANY
Electrical and wiring
Blue Sea Systems 5025 ST Blade Fuse Block - 6 Circuits with Negative Bus and Cover
http://smile.amazon.com/gp/product/B000THQ0CQ
Illinois Industrial Tool 82986 Heat Shrink Wire Wrap Assortment (Pack of 127)
http://smile.amazon.com/gp/product/B004E2Z10E
Note that these items are set up for a 2007 H3 with the I5; different years could have different parts. Be sure to verify your part numbers and/or use the vehicle identifier tool in Amazon (which itself is not perfect).
Drivetrain
Amazon.com: Genuine GM 26064028 Differential Drive Pinion Gear Seal : Automotive
Buy Genuine GM 26064028 Differential Drive Pinion Gear Seal: Differential - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
amzn.to
Brakes & Suspension
Miscellaneous
Tools & Other
