Empigt
- NW arkansas
I'm having a problem with a 2008 hummer 5.3 alpha h3. This problem has been going on over a year now. Only codes thrown are o2 sensors and low voltage to from ignition switch. I've read about all sorts of problems causing this. So my first go to was the throttle position sensor. Did that with no fix. Installed a new ignition switch, still no fix. Put new speed sensors at each wheel. Still no fix. I checked for any broke or wore wires in the engine bay. Pulled the plastics off the harnesses and nothing broke or wore. I seemed to notice if I wiggled wires under the dash it would start. So I thought the aftermarket keyless entry/remote start may be causing the issue. So I had a professional rip out the old system that had a chip key bypass module, and install a new full system. That didn't work either. But the hummer seems to start better when it's cooler so if it starts in limp mode if I run the a/c and get the cab cooler inside, then shut it off and then start it it will start in normal mode. So far have invested close to $1500 just trying to fix this issue. I hate going to a dealership as I know how much of a rip off artist they can be. I had a friend take his convertible to a dealership because the power top wouldn't retract correctly. The said a new top assembly was needed at the cost of $3000. He brought it to me to see I I could repair it. It took me 5 minutes to look it over and find an small folding umbrella and fallen behind the seat into the top bow assembly lodging it. Pulled it out and all was fine. And I'm sure that dealer ship saw that and was about to charge $3000 for what I just did for free. Sorry to make this so long. Any help would be great. Thanks.
