rsm688
- mississippi
Okay guys well I have pretty much eliminated all my noises on my H3 except what I am pretty sure is the body mounts popping. I can hear it in the front and rear depending on what kind of bumps I hit and it almost sounds like popcorn popping. I sprayed silicon spray on them all which helped a tiny bit but not much. I saw a thread where someone used rubber washers under the lower bushings to add pre-load to the upper bushings as apparently there is not enough pre-load which is what causes the noise.
Has anyone on here done this and had good results, or found any other cure to the problem? I was either thinking nylon washers or either just cut like 1/3" off each of the bolts so I can tighten them down more to increased the pre-load without needing a washer in there.
Thanks,
Spencer
Thanks,
Spencer
