atvspeed4
- massachusetts
They twist but endlinks don't have enough deflection to allow it to
In this old shot I was actually balanced here and had my mechanic friend look in there and the a-arm was not touching in this real world situation.
So it is a combination of factors that determine how your front end is setup and reacts.
Btw, thinking more about the bumpstops in a crawling situation, if you've got adjustable compression damping, you can have a bump set very slow, where it will react like stock on the street in an emergency situation, but in a crawling situation it would do what I want it to, by allowing the uptravel.
If an H3 is hammering the metal stop with extended shocks they are either shot or you have cranked the torsions too high, or you are pushing too hard.
I added limit straps when I first did all my mods in case there was a problem hitting that stop. I later decided they were not necessary when I came down from 24 inches to 23 1/2 back in 06. I did see evidence of some light touching the metal stop after that after hard trails.
In this shot if you were disconnected though, your tire that's in contact would be shoved up more, and the tire that's hanging would be against the metal stop. The stiffness of the sway bar is the only reason that it's not.
Ok I'm trying to see it the way you are.
I don't think disconnected would shove up more, I cannot explain it well but at steep full up angles things will only go so far before the bar reacts from the other side or in this case maybe other components.
Here is what I think, my tire on the ground with extended sway bar links has probably allowed all the up travel there is from the cv's and my tie rods that allow up to 30 degrees. The longer link pushes the sway bar at that end up higher but having no resistance on the tire in the air at the other end the sway bar can only press down as far as the components on the other end will allow, which in my case is short of the metal stop, in most cases. I have painted the under side of the a-arm several times so I can check if it hits. I only rarely see where it had touched but not hammered it enough to bend an a-arm.
Does that make sense?
Back to the main discussion, will the longer end links help achieve that extra uptravel we are looking for? Disconnecting sway bars is fine for rock crawling, on the high speed a simple turn could end up in a rollover!!!
I disagree on the UP. On a steep uphill there's admittedly not as much weight n the front, so I couldn't expect being disconnected to change much there, but for me, the same feature being connected to being disconnected the difference was just under 4". Also, if you're cranked and running bigger bumpstops like most are, there's no way you can get full uptravel, as THAT will limit the travel as well.
Using longer swaybar links flattens the arms some, increasing leverage... but not enough that it actually articulates from side to side noticeably... I've seen pic after pic of H3's, and I've never seen one anywhere NEAR full flex with the swaybar connected. I'm really surprised that you even suggest that, as you know how stiff this swaybar is. Just looking at the LCA angle in your pic, you can tell the opposite side is keeping it from drooping hardly at all.
Same situation with the JK, a buddy of mine had his E disco act up on him, he has proper length swaybar links... and the thing wheels like an H3 without disconnecting. Almost ZERO front flex. As soon as I looked at a pic I could tell his wasn't working properly.
Show me a single pic of any H3 connected that looks like this, and this is where I was only disconnected on one side, and the swaybar bottomed out on the nut on the other side, so it limited travel a bit still (going to the other side was noticeably better)
Look at the obvious difference in LCA angle here:
I only point this out to dispel the myth that the 3 articulates any more than 2" or so without disconnecting, and that with a good bumpstop system you could have a disconnected system WITH flex, that also has some more risk mitigation from the issues involved in disconnecting, and also have a more street friendly vehicle than I did.
Do you think running it like that could cause steering racks to break more often as the tie rods steeper angles would be leveraging more on the rack ends??
I tried to be conservative in all my changes and still be reasonably reliable by changing components to handle the changes in forces. Works for me, so far.
It seems here there is abit more up. Assuming there were different bump stops, can this be achieved without disconnecting? Some sort of mod to the sway bars?
As to the steering rack mod, I too have the Hunner sleeve, works great as it reduced that clunk I used to feel, even before being leveled on that stock rubber sleeve. The truck actually measured 21.5 inches to bottom of the fender, so my truck was way low to start with. The monster new aluminum clamp being made looks very promising. Im hoping for something to fix this issue once and for all, and honestly I don't have the skills to weld another bracket in the middle.
