Has anyone had any run-ins with the C0710 code on 2008 H2s? The "Service Stabilatrak" notice is on the dash and it appears to be related to the steering wheel position sensor. It has been intermittent. I cleared the code and it took a while to come back. It came on yesterday and then this morning it was off. Based on some other, non-HUMMER forums, it mentioned that spark plugs, ignition wires, throttle body cleaning, etc could be an underlying reason for this code. I recently replaced all that stuff as routine maintenance and then 3 weeks later, the code showed up. I don't see those being the issue. Another thread also mentioned that it could be an issue in the connection between the sensor and the plug. I checked it out and don't see any corrosion or anything. I just ordered a new sensor but wanted to know if there were any other potential causes out there.
