C1R HitchMount Harness Update + Installation | Diode Dynamics
Diode Dynamics
LED Lighting Experts
St. Louis, MO
In this video, we’re explaining an update we've made to our popular C1R HitchMount harnesses. Some customers have reported flickering or trailer detection–so our engineering team quickly came up with a solution!
Our C1R harness now includes a t-tap connection for those who wish to use this harness with a separate power source, which is connected using this amp connector and tap wire. The wire with this amp connector provides a constant 12 V source and is the power feed for the light, also controlling the timing of the safety strobe feature.
Anyone installing a C1R HitchMount can use the included tap wire to tap a constant 12V source, however, it is not required for installation. But if you're experiencing flickering or a trailer detection, the tap wire is the best solution.
Thanks for watching!
Get your HitchMount LED Pod here:
HitchMount LED Pod | Trailer Hitch Mounted Reverse Light
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: contact@diodedynamics.com
Phone: 314-205-3033
I noticed that there's a new kit for the Silverado 1500 (I returned my original, new-release one since it didn't function properly). Does the new kit require a line tap like described above and if not, how does it overcome the original functionality issues?
Diode Dynamics
St. Louis, MO
The harness update video on YouTube above has been the solution to 99% of vehicles reporting issues. If you haven't tried this new harness, it should solve any issue you're experiencing!
