H32NV
- Golden, CO
So Ive been having an issue with rough idle, and reduced power, and have thrown a few codes here and there for high idle rpms, cam sensor bank A malfunction, cylinder 1 misfire...etc. I took it to the dealership back in September '11 because I am at 83k of my 100k warranty, and they told me that sensor components on the engine arent covered under powertrain. That doesnt make too much sense to me as a warranty plan, I think everything that needs to be functional to run the engine should be "covered" if they call it a "powertrain" warranty. With this first visit, the code was for a Cam Sensor Actuator, and they called back and said that this part was indeed covered under warranty, so they replaced it. The truck drove great for about a month, then I started getting a really rough idle, hard starting, but this came and went occasionally, and while I was in Moab for the BSHS week, Speedy alerted me to a loose sensor wire problem that he has heard of before, we tugged at the wire on the cable housing for the intake side Cam Sensor, and the engine started running fine again. Last week I was down in Phoenix, and I got a really rough idle again, this time more pronounced than the first, I tried strain relieving the cable at different angles, nothing seemed to help, so i pulled the code, it was a Cam Sensor Bank A Malfunction code, the part was only $29.99 from AutoZone, so I replaced the cam sensor. WOW what a difference that made! I had been concerned for a while that my engine was either wearing out or losing cylinder pressure or timing or something because I wasnt getting the same amount of power out of it that I used to. On a side note and a bit of a separate issue, over the last 20k miles i've noticed decreased acceleration potential, nothing bad like when the CEL is on, but the truck has definitely lost some pep in its step. Replacing the cam sensor seemed to clear things RIGHT UP. Not only was the engine idling normally again and running well, but it seemed to have the same amount of power as the day I drove it home from the Dealership. I was able to hold 75mph on cruise control from Phoenix all the way to Flagstaff, and have never been able to do that especially on some of the hills. Very happy with the results, and this makes sense, as with a VVT engine and any engine at that, timing is critical to produce max power/fuel economy.
Well as of last night, the problem is back. Rough idle, and decreased accelleration even when it clears up occassionally, no CEL, and I imagine it will take a few days before I get a CEL like the last few times. I'm officially out of ideas, and after talking with some of the mechanics, I am not really sure anymore that there are any Aces in the shop at the GM dealer up here....
http://www.hummerforums.com/forum/hummer-h3-17/cam-sensor-12751/
