Change oil light ?
Exodus
Alaska\Philippines
08 3.7 base manual
So i changed the oil on Saturday, the change oil light came on Monday
how do i eliminate the change oil light without going to mechanic ??
TIA
Korby7
Utah
I have to google search it every time.
Accelerator Pedal Method (Most Common)
    • Turn the ignition key to the ON position without starting the engine.
    • Slowly press the gas pedal all the way down to the floor and release it three times within five seconds.
    • Watch for the oil life message or light to flash or turn off, which means it is reset.
    • Turn the key back to the LOCK/OFF position.
Instrument Cluster Stem Method (Alternative)
    • Turn the ignition key to ON/RUN with the engine off.
    • Press and release the trip/reset stem on the instrument panel until the screen shows OIL LIFE.
    • Press and hold the stem down until you hear beeps or see a confirmation message.
    • Turn the key back to OFF.
Exodus
Alaska\Philippines
thanks a lot, couldn't get the pedal method to work {dumb operator error } but the stem method did the trick
