- Tardville
So I was working on CaseyS's front axle the other day, and I noticed the outboard mounting bushings were toast. This is very common on H3's and I've always suspected they play a part in the AAM-7's high failure rate. When these bushings go soft...the axle is free to flop about and pull itself apart, (especially when spinning tires suddenly get a bite). The dealer wants $102 for each side, and of course...nobody had them in stock. Casey had already come up with his own fix for the crossmember bushing but, the original outboard bushings had 230K miles on them! A couple of on-line places offer bushings but, either only as a set (including the crossmember bushing)...or as an "exchange" which takes time. I was in a jamb and needed to get something done pronto. As you can see...the bushings were junk, and I only had a day to find a fix...
I started by pressing out the old bushings. This leaves a thin metal sleeve in the "ring" of the mounting bracket. A quick burst with the sawzall and those come out easily. What you are left with is a totally bare bracket, ready to accept the bushing of your choice. I just happened to have some tube-bushing kits laying around and wouldn't you know it...they fit perfectly...
I had to cut them down in length, so the two bushings bottomed against each other when pressed into the ring. Then I cut the inner sleeve down about .010" shorter, so it would stop me from over-compressing the bushings when tightening. Next I grabbed some round bar stock and cut some thick washers for the top & bottom. Casey had shimmed his axle housing down to gain some much-needed oil pan clearance, so I made the upper washers extra thick for this reason...
Here's the finished product...poly-u bushings ready to go...
This is a very inexpensive mod, and I am making it "standard equipment" on all AAM-7 axles that roll through here. I'm looking for the bushing box (something for a Toyota I think). When I find it...I will post up the part number. I used a lathe to modify them but, it could also be done at home with a hack-saw and some fender washers. Total fab time was less than an hour.
