No. You do not want to take a full size anything onto Black Bear Pass, not just for the switchbacks but also some narrow spots on the trail. Black Bear pass starts south of Ouray and leads into Telluride. Then you can take roads back to Ouray, or take Imogene Pass back to Ouray. While Black Bear Pass is a one way road, Imogene can be taken in either direction.Veeeeeery interesting. I wonder if a Power Wagon will fit on those tight switchbacks on... is it Black Bear pass that leads into Ouray?
I have pondered the idea of an H4O trip to Ouray. It can only be done in July or August as that's when all trails are open. We'd have to plan plenty in advance and try and book a block of rooms. Maybe 2022?
Would an H2 be too big?No. You do not want to take a full size anything onto Black Bear Pass, not just for the switchbacks but also some narrow spots on the trail. Black Bear pass starts south of Ouray and leads into Telluride. Then you can take roads back to Ouray, or take Imogene Pass back to Ouray. While Black Bear Pass is a one way road, Imogene can be taken in either direction.
Not for the turns. Will be tight on some areas but you'd be fine
You jumped on that even faster than I thought you would! I think an H2 could hug the inside wall better than a pickup, moving it over an inch or two. Shorter wheelbase would also help.Cuz, you see.... H2's are not full size :giggle:
Only ones with Rancho lifts will fit. [emoji16]What about an H3T with a longer wheelbase? Sounds like a fun trip to me.
I will stay tuned.Not for the turns. Will be tight on some areas but you'd be fine
Sent from my SM-N986U using Tapatalk
