Dana 44 for sale...
$3000...must be picked up in Indy. Specs below..
Specs below...
  • Stock large-tube GM Dana 44 housing
  • Stock GM 3/4-ton shafts 30 spline inner/19 spline outer
  • New Spicer ball joints
  • New Spicer u-joints
  • All new bearings & seals throughout
  • GM flat-top knuckles (required for crossover steering)
  • Spicer 4-series single-track diff with 4.56 gearing
  • Ford strap type yoke
  • THORparts ABS hubs (accept your stock H3 brake system)
  • THORparts 3-link coil-spring brackets (pre-welded)
  • Warn Premium lockouts
  • 1/4" steel rock cover
Can provide additional SAS items if desired (Frame plates, driveshaft adapter, frame brackets, link bars, springs, shock towers, steering system, trackbar, tie-rod, drag-link, shocks etc.) Can also make mods if desired (re-gear, lockers, shafts, etc.).
Korby7
Utah
Shame it’s so far away. It’d take the guesswork out of piecing one together on my own.
jakesz28
Cabool MO
I wish it was that easy to find a 60 that easy to swap in. I need more time so I can work on my many different projects.
Kcaldwell04
Tennessee
Interested......we have talked before about doing a swap on my h3 could you call
Me when your are available to talk? 870-718-5886
