H3 Disengage transfer case to Neutral for towing Behind Motor Coach
ReRun0007
The Villages FL
For over 2 yrs I have lost the capability to disengage the axles on '07 H3x so it may be towed behind motor coach in Park
Have reviewed owners manual towed this hummer 4 10 yrs stopped in 2008
Need to identify the prob and how to restore the capability to tow behind motor coach
after holding the 1st 2 drive buttons on dash the red "N" fails to eliminate
Richard The Villages in FL
1 owner white 93K mi H3x a head turner
perfer replies via e-mail to rdi0007@yahoo.com
ReRun0007
The Villages FL
darn......... booo on me..... 1st and 3rd buttons pushed for 10 secs and "N" lite illuminated steady tested by rolling Hummer while in park tuvm
BTW >>>>when I transfered back to regular 4 wheel drive a fairly loud scrape/clang/gear chg/noise occurred ..... something must need lubrication? what do U recommend
A pretty loud clunk is normal. There's nothing to lubricate except to make sure you're changing the transfer case fluid on a regular basis. I would change it often, like every 20,000 miles. Takes less than 2 qts of Dexron VI, cheap maintenance that goes a long way towards prolonging the life of the transfer case.
