EBay- GM Performance Catback Exhaust for Alpha
Timgco
Hugh Hefner
Colorado
you'll want to take that to a muffler shop and have them cut/ clamp the tips for you. otherwise you will pinch them shut/ flat on the trail. I did that on one of my H3's, I had the B&B Exhaust with the twin tip setup like that. sounds great on teh I5. deep, no interior drone either. I think this may be the same exhaust, so you should have good results, jut be careful on the trail.
H3-ING
AdventureTime
Newport Heights
Most definitely. These tips are big and hang out past the bumper and are much lower than the stock set up.
Most likely the tips would be pancaked at some point in time if you wheel your rig.
I used a sawzall to remove them.
Here is a pic of the alpha set up.
Installed, tips removed.
