metdetdist
- brooklyn ny
Hello everyone. New at this and need help or suggestions. I have an 2008 H3 with 23,000 miles and have some problems. I hardly get to use it, thus I don't know as much as I should after 4 years. Lately I noticed the LEDs on the radio goes on & off, the dashboard gages go on and off, and on two occasions, the headlights turned off for a period of time. These alternate on & off, in other words my dash may light up, and in turn the radio goes dark and vice versa. After Sandy, they blamed the problem as a salt corrosion problem, but its not the case. Water never entered the H 3, as the water was BELOW the door level AND the dark radio happened before the flood ( the dark dashboard and headlights just starter happening ). They suggested the H 3 should be considered totaled, but its basically running fine other than the electrical problem, which I don't think its releated to the flood at all. Any suggestions ? I hate to give up my Hummer, but I'm worried about future problems. Could it be a factory defect ? How can I figure this out ? Any suggestions ? Another problem: the other day I put the H 3 in reverse to back into the driveway, but it was really dragging in this gear. It felt like the wheels were against the sidewalk, as it stopped the vehicle. In drive I had no problem at all, only in reverse. It lasted for 5 or 6 tries, then like magic I had absolutely no problem backing up. Never had that happened. I appreciate any suggestions. Thank you Ettore metdetdist@aol.com
