Engine Oil Pressure Sender - Replacement - what I did that may help others
mmesa005
California
My engine oil pressure gauge was pegged at full pressure leading me to expect that oil pressure sender was faulty. After watching a video on Youtube regarding the replacement of the oil pressure sender on a GMC Sierra https://www.youtube.com/watch?v=oO0T1nJdamY I found it was easier to do the following:
  1. Using my phone camera I took a video of the area where I knew the oil pressure sender was located. Just to be certain I had identified the correct component.
    1. http://i1212.photobucket.com/albums/cc454/mmesa005/Hummer H2/oil pressure sender.png
    2. http://vid1212.photobucket.com/albums/cc454/mmesa005/Hummer H2/20150822_170842.mp4
    3. http://vid1212.photobucket.com/albums/cc454/mmesa005/Hummer H2/20150822_182951.mp4
  2. Using a small step ladder I stepped up to tire height and leaned over the fender area near the firewall. Using my right hand I reached in from the left side of the H2 (facing forward) and along the firewall. I was able to disconnect the wire and get the socket on the sender.
  3. A 1 1/16" deep socket, universal joint, 2 x 6" extensions were the tools I used.
  4. Took about 1 hour to remove and replace the sender taking into account trial and error of finding the right position for my arm to reach behind the engine.
Note: I only have the pdf version of the service manual and it was not helpful in this case.
