Fender removal
Panzer07
Ontario, CA
For the front ones you need to remove the front grill...after that remove all off the push pin that are alone the outer edge from the actual fender...then just get to flat head screw drivers and starting from the front of the truck/fender start pulling gently at the fender towards you and with the screw driver push/press on the right and left side of the clips that hold the fender to the body frame. be careful not to yank at the fender too hard or u might brake the clips. There's nothing to it just take your time and you'll quickly get the hang of it
Torres
In addition, make sure you have some spare clips, those tend to become more brittle as the truck ages and its very likely you may break one (same applies for the grille)
derian06
Red Rockett
Madison, AL
I was thinking about taking off my fenders to bedline them, but theres no way i'll beable to do it without loosing or breaking something.
