Few Questions
HUMMER INVESTMENTS
[o O IIIIIIII O o]
Black Hawk, SD
Well I have a few questions;
1. Today when I went to get some stuff from the H1, I noticed that none of the lights lit up when I opened the door. So when I saw that, I thought I might as well start it to see if I could figure out the problem. When to go and start it, I heard i guess a "muffled" beeping sound that usually is louder ( Its the door beeper ), and all the lights on the dash are lit up, but they are also "faded" too. Also in addition to that, the speedometer went from zero counter-clockwise to 100. I tried to start it, and nothing happens. The lights on the dash are one but dimmed, and the lights on the Piaa light controls are lit up also.
2.How does the military or you guys with long antennas keep them down?
3. I believe under the doghouse, where the HVAC hoses exit out and under the truck, I can see the ground and sunlight, Is there anything I can do to cover the hole?
Thanks for the Help!
HUMMER INVESTMENTS
[o O IIIIIIII O o]
Black Hawk, SD
1. check the ground on the batteries
2. http://www.american-milspec.com/p-79-new-military-radio-antenna-tie-down-strap.aspx
2. http://www.ebay.com/itm/Military-Radio-Antenna-Tie-Down-and-Antenna-Ball-Small-/160657207330? _trksid=m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%2BIA%2BUA%2BFICS%2BUFI%26otn%3D31%26pmod%3D110737903983%26ps%3D50#ht_500wt_1413
3. Duct tape cures everything.
1. Thanks, Even though already answered, Really appreciate it!:wink:
2. Same as #1
3.:giggle: Answered also, using a type of silica
