Truck seemed to ride a bit odd today. Gandered around and found this.......see pic.
Should I just reorder some factory ones? Or aftermarket? I know the poly ones would give a harsh ride but maybe there is something you guys can recommend that's an in between material.
Two options. Oem or trailduty extended bumpstops. If you're leveled up front with a torsion bar crank, you may like the Trailduty ones better than oem. Some claim it's a harsher ride but you'll have less nose dive when braking.
