Front Diff Mount Bushes (Front)
Chook
Brisbane (Australia)
It looks like you have to change the whole bracket though (Like the crossmember one)
I tried to call my dealer yesterday for a price/availability but he didn't call back........... Which dealer did you get yours from Skippy ??
I think it's better to get new factory ones. Replacing then is a PITA. I've done it twice and neither time was easy, pretty or cost-effective vs new OEM brackets.
In seven years I've broken 0 drivers side ones and 2 passenger side ones, a pretty low rate I think.
I worked through this with Dwaine and there wasn't much upside to producing these bushings, at least not in a consumer friendly package.
Sent from my SM-N900V using Tapatalk
nugget
Where Gunner_45 can not find me
Hi Chook...I have replacements ones which I did when I had the H3...would be in the build somewhere. I made them as 2 piece so once you have initally replaced them you don't have to rip the whole thing apart.
Cheers
nugget
Chook
Didn't want my Hummer off the road while I waited.
As a temporary fix I did some research & found bushes which were close.
Then shopped around till I could find any that were in stock.
Ended up Pedders Suspension @ Geebung they had "EP6626" in stock (same as Nolathane 45626) which are for a Ford Focus Control Arm
I had to cut off 5mm off ea Bushing & 10mm off the crushpin for a nice snug fit.
