I was driving Saturday morning and started feeling and hearing some popping that was not normal. The previous owner didn't take very good care of it so I've been fixing little things along the way. Pops and clunks are not uncommon but this was different. I pulled into a parking space and slid under the front to shake some things. I noticed the driver's side sway bar end link was loose, but I had it disconnected it when changing the CV axle on that side so I wasn't too alarmed. Then I noticed the CV boot on the hub-end of the axle was twisted. It looked like the hub spun and the diff didn't or vice-versa. I then tried to limp it home but only got about 200 feet before it quit pulling. I tried all three 4WD modes and nothing. Finally after sitting blocking traffic for a few minutes and moving the transfer case from neutral back to 4-high lock I was able to start moving again so I pulled it into a parking lot and it quit pulling again.
Three towing companies I called said it'd be "a couple of hours" before they could get there, so I called in a family member with a tow strap. I put the transfer case and transmission in neutral and he pulled me home. Something in the front end sounded like rocks in a blender while being pulled. I know I could have potentially damaged something worse by pulling it, but I figured I didn't have much to lose.
I had suspected a broken shift fork prior to this since I experience regular front end binding. I assume that's confirmed at this point (or some other TC issue) since it wouldn't pull in 4HL or 4LL either. Obviously there's something broken in the front end too, so my plan of attack is as follows:
Remove both CV axles, drain diff and open the cover to survey the damage.
Drop transfer case and replace shift fork
Reinstall transfer case and verify function by driving in 4HL
Address the broken parts in the front end. I'm assuming a rebuild will be necessary.
Does this seem sound logically? I don't have a ton of money so I'm trying to repair rather than replace as much as possible. Thankfully I have another vehicle to drive so I have the luxury of time somewhat, but I'd like to get it moving under its own power soon.
Any other ideas?
Any other ideas?
