Front Wipers Not Working
Odimus
Maine
left wipers on and the froze to windshield...didnt realize I left them on next morning till it was too late...swapped out the fuze which was a 10 instead of the 25 and it still is not working...been a few days so more than enough time to cool down...what's the likelihood the diode or relays burned out before I go looking at a new motor or fuze box...rear wiper still works as well as the washers...
Both wipers not working (left/right). If both probably electrical; if one, could be a stripped spline. Also, I believe there are two fuses for the circuit one to feed the switch (10 or 15 amps) and another for the motor (25 amps). Check the manual. I also believe the smaller fuse is also labeled sunroof/frt wiper; regardless if a sunroof is installed. But this is all from memory.
