Krackerzack
- Mississippi
Has anybody used the factory fog light switch to run roofrack lights? I purchased the switch and once I realised it was a momentary switch, I knew it wouldn't be as easy as I thought. I have done a little research and there are a few videos out there on how to add headlights to other gm models, but I don't believe the h2 is prewired like they are. The harness to the switch is missing the 3 pins that operate the lights and will need to be added, but it looks like the spot in the fuse box for the relay is wired. I stopped by the gm shop today and I was told that there is no harness to be sold separately for the fog lights and that the bcm would need to be reprogrammed if it was added. I can seem to find anything that points me in the right direction.
I am thinking about just adding a latching switch relay directly behind the factory switch to run the lights, but just seeing if anyone knows of a correct way to do this.
