Good Switch Needed!
Ron46
Capt.
NJ
I keep buying advance auto led circle switches and they blow in the first five minutes I have them, or they break. Does anybody have any sggestions for switches with Led's and that are HD. thanks!
For blowing, are you running the switch(es) on the power side of a relay or on the ground side of the relay (preferrable)? For breaking...use a smaller hammer:giggle:
I have a radio shack LED and have had it for a few years and so far so good. But they are run on the ground side.
Ron46
Capt.
NJ
OK thanks guys, and F5, I don't know what you mean on which side, but I am using a different switch for my piaa lights. When I hook the 3 wires up to the new switch, it works for about 1 minute then it blows when i get the switch in place?
Are you using a relay for those switches or are the switches going straight to the lights? Do your switches have a good ground?
Top view is a switch wired to the hot side of a relay's coil circuit. Bottom view is a switch wired to the ground side of the relay's coil circuit.
Red wire is directly from the battery
Dark red wire is to the accessory
Yellow wire is from ignition B+
Black is ground
Ron46
Capt.
NJ
They are coming from a relay from the existing Piaa wiring harness. Its a brand new Piaa wiring harness, the only thing is I wanted to use a different switch, so I cut the wires right before the switch, so it has the three wires, A ground, Load, and power wire. Every time I hook up the wires to the switch, it works, but then when I disconnect them to run the wires and put in the switch, the switch doesn't work and neither do the lights. Im confused so I think its just the switch inset that good. Also after the new aftermarket switch doesn't work, I re-hook it back up to the piaa switch and it works fine.
Ron46
Capt.
NJ
Ok, so I have the 2 wires coming from the relay going into the switch, but then instead of ignition B, I have the 3rd wire coming straight from the battery because I didn't know where to tap into a power source? but it works everytime with the stock PIAA switch, and it works the first time with the aftermarket one but then it usually blows.
Did it ever work or is this a new install? Also perhaps your new switch doesn't have a high enough power rating (possible, usually doubtful). If you have a multimeter, test your ground for your switch. If you don't have a multimeter - get one! :)
Ron46
Capt.
NJ
The lights have always worked, I just never put the switch inside the truck lol, and I never new there was a power rating on switches, maybe the one I keep getting is too low. I have to check into that thanks! and yeah I don't have one down at college and I have been meaning to get one, but I always get sidetracked and forget :wink:
Steve #1
TEXAS
The amp draw of a 30 amp relay is minimal. You should be fine with just about any little ol switch. F5 is correct that it is better to switch the ground side of the relay, but often times LED switches are set up to switch the positive side and since LEDs are forward-biased you cant switch the ground without damaging (burning out) the LED.
Look at your relay and tell as what is hooked to what using the numbers (85,86,87, 87A, 30) as well as the terminals on the switch.
Kurt
Orange County, CA
Good switches?
Eaton Cutter Eurostyle or Carling Contura. You can get the bezel clips and gang clips so you can install banks of witches, plus you can get a clip on harness adapter, so you can crimp on automotive spade electrical connectors onto your wiring, lay them inside the keyed harness adapter and clip it closed and have a OEM style plug to hook your wiring up.
The eaton toggle switches are an OEM match for the H1 if you want to keep the factory look, and you can get them in many configurations, with different illumination options with silk screened graphics.
The switches can be expensive, $7 for a blank, non illuminated toggle 2 pole switch to $20+. They look sharp if you do a clean install. These are commercial grade switches so they are rated for a few hundred thousand to a million + toggles. If something breaks they are serviceable, the switch, light and toggle clips are replaceable.
I see a few off road shops offer the Carlings all prewired into generic control panels with rockers and winch controls complete with illuminated graphics. I saw some in person in Culver City, CA at Dirty Parts on Washington Blvd. I would have rent with Carling for my switches but I already gotten the Eaton Commercial truck switches at that point.
