The_Mountain
- Cow Hampshire
A month or so ago (just before the great forum hack), I had taken my truck in to have the trans checked. While the tech had his scan tool plugged in, it found a code in the air suspension. The message was something about loss of communication between the BCM and the air suspension. I asked here on the board if anyone knew what the BCM talked to, and if there was a "usual suspect" I could look for i.e. if the problem was usually caused by a particular cable coming loose, or if there was a specific sensor that typically caused this problem. Also, if not, was it worth crawling around under the truck looking for loose connections.
It looks like the suspension isn't leaking, so far as I can tell. Does anyone know what the normal pressure is supposed to be? The readout was 43lb according to the tool. Also, my left rear corner sits a bit low, and the sensor reading is 2.2v, whereas the right side sensor is more like 2.6v. I didn't get a chance to see if those are the voltages the system is expecting, or if the left-rear is out of spec but the system can't correct it. I'm going to try to see if the mechanic there will let me buy time with that tool to see if I can force the suspension to level out. I messaged the guy someone suggested I contact here on the board, but it looks like the forum reset wiped that out, so if someone could re-suggest the name of the member who is supposed to be knowledgeable about the air suspension, I'd appreciate it.
