speedy
Sir Welds a Lot
- Dayton NV. Battle Born!!
looking for the wheel mounting surface to wheel mounting surface measurement for the rear end. Working on a project for Bebe's H3
Thanks
Thanks
I measured outside of tire to outside of tire and then subtracted the distance from wheel mounting surface to outside of tire. I am pretty confident that it's right on. If I have time tomorrow before I go to work I'll jack the back up and pull the wheels off.
Sounds like it would be perfect!
ABS plugs right in?
That would be nice . Not counting on it.
Are you gonna drill holes on the flange to 6x5.5 bolt pattern?
Not sure if there's enough meat to redrill. Probably just get some yukon axles made.
I gotta go measure what a stock H3 rear end is...just curious
