- Meridian, ID
I recently got some fan on fan shroud noise when the truck is all twisted up. I figured my body mounts were shot. There are 8 body mounts total, 4 on each side and 2 on each mount, 1 upper 1 lower, so 16 total. I replaced the front 2 (one on each side) upper and lower then the the 2nd one back I could only get the lowers in. I can try with more jacks but if the front ones got rid of the fan to fan shroud noise do I have to replace the rest of them? Will having newer ones up front and older ones in the back be an issue with body flex or cause issues?
From what I saw the fronts were the most worn out the other ones didn't seem as bad.
