- United States
What extremes does anyone's STFT go between? Mine is about + to - low 20%. Back story: Had a cracked exhaust manifold. I let the shop do it because I didn't want to screw with broken bolts, etc. Reputable independent shop. New up and downstream Delco O2 sensors. Had a P1133 set after 24 miles, the coolant temp went crazy, then quit working. Also started going between open and closed loop more or less at random. Took it back to the shop which said a bad ECT sensor could cause the 1133. Not so sure, but I'll take his word....for now. Replaced ECT sensor, car ran fine for 101 miles then 1133 set again. Car still runs fine with exception of the fuel trims being erratic going from one extreme to another. This, of course, results in a slightly variable idle. Sensor voltage is varying, so it is working. Is it possible the code doesn't stem from something else and I just got a bum sensor that truly isn't feeding the PCM info fast enough? I'm not a person to throw parts at a problem, so I wanted to get some input first. Thanks in advance.
EDIT: I think this mystery may be solved. I'll get a few hundred miles on it and post back.
