Help Starr hid headlight
Ben
Winnipeg
Got the light today, luckily no instructions, so after plug everything today which wire should I cut? I remember something about passenger side wire need to be cut? Where can I found instructions online ? Any help would be great
Thanks
Ghostbuster
I heard it was plug and play. No need to cut anything. I mean for the price... It better be plug and play.
Do you have any wires that aren't connected?
Ben
Winnipeg
I plugged and played , light doesn't come on, but I got power from fuses that come with harness
Ghostbuster
I would double check all the connections and then call the people at Headlight revolution and politely ask them to email you a copy of the instructions.
Ben
Winnipeg
After I got home with only fog light on, I run some test, I checked all the connection was good, I checked hid relay harness,far right top pin off relay has constant 12v, I disconnect the hid connector and plug old headlight bulb back on, no light at all, I turn the high beam on and off I can hear relay clicking dunno it's high/low beam relay or headlight relay, so one of those two factory relay must working, going to check the fuse 40&41 tomorrow and relay, still can't rule out defect @ headlight
and I do shoot headlight revolution an email, hopefully I can fix it tomorrow
Ben
Winnipeg
Problem found, I checked factory fuse box fuse box for headlight, both 10A fuse blown, as I replace fuse even switch to bigger fuse, driver side 3 pin headlight connecor which connect to the factory plug after the adapter they provide start smoking, I guess it's dead shot inside or whatever
Traxx
PNW
You've got something wired wrong. I've installed two kits, takes an hour, both plug and play.
Ben
Winnipeg
Lucky me, I take the pic and email headlight revolution, they said somehow different adaptor and wiring wrong , so I mailed back
