Hood Louver Question
kshummer
Kansas
I have an '07 H3 and I have a question about the hood louver. It is a chrome louver and I noticed that when I was in the car wash the other night, there was a black piece of weather stripping or something pulling out of the top of it towards the windshield. What purpose does this strip serve? What holds it in place? I simply tucked it back in place, but it looks like it might come loose again. Do I need some sort of adhesive strip on it?
The hood louver is held on by small plastic tabs that you can see on the underside of the hood. They are notoriously weak and this louver is notoriously the only recall on the H3. If you don't want the dealer to slather adhesive to your hood (effective solution) you can secure your louver with your own adhesive or other means, as I'm sure some will chime in here. I believe that strip is simply a transition piece that is a buffer between the hard plastic of the louver and the paint.
crawler
Yes. High-strength bonding tape is a proven alternative to screws, rivets, welds and other forms of mechanical fasteners.
Unlike screws or rivets – which join materials at a single point – high-strength bonding tape permanently adheres one substrate to another while spreading the stress load across the entire length of the joint. Once materials are joined with 3M™ VHB™Tape a virtually indestructible “weld” is created.
Skyscrapers, cell phones, refrigerators … all rely on high-strength bonding tape to complete one or more steps in the assembly process.
Extraordinary strength, conformability, versatility and UV- and weather-resistance makes 3M™ VHB™ Tape great for bonding:
• Glass • Painted surfaces
• Metal • Painted/sealed wood & concrete
• Plastics • Outdoor & harsh environmental applications
• Many more!
