How do you get into 4 high lock ?
MPR_OffRoad
Oahu, Hawaii
Hey guys How do you get into 4 high lock ? Bc i know with 4 low lock you put it in neutral then push that button but what about for 4 high lock ?
FactoryOrdered2010AlphaT
Canada
You do not need to be in Neutral to switch into 4 high lock. From 4 Low lock, at a low speed, press the 4 high lock button. You should feel the change. If it flashes and doesn't change, you may have a transfer case issue. If the middle light turns solid, you should be in 4 high lock.
