Hunner rear wheelwell body seam
This has bothered me since 2006 when I got a rock caught in there running 33's. Came up again when I installed 315's. Came up again when I ordered chains for the 315's. Ok, that's it, mod time, get out the grinder. I was prepared to weld and caulk whatever was under there. Turns out no welding required, already caulked, only needed a little blast of non-reflective nature color camo black and a good coat of mud.
I had hope and I got change, three pieces fell out.
with 33's
35's
now if photobucket will rotate
Drivers side is easy, pass side the grinder rotates so you might catch your hair on fire! Wore a face shield and should have worn a hat!
Just another Hunner tweak mod.
Portager
Silverado
Nice mod Hunner.
I'm going to have to look at the H3T and see if I have the same problem. Especially when I go to 35" tires.
Or you could just ride on 33s :)
Thanks for showing the work involved so others can do this mod.
ReconH3
Guardian Angel
Raleigh, NC
I was planning on doing the same thing. :) Good to see a write up so I know I won't get any surprises. Thanks.
"Ex Umbris Venimus"
Sent from my iPhone
